The amber on the side of the headlights really bothered. I didn't want to tint it or black it out cause it would have looked weird and off IMO. So I decided to just take it off. Pretty easy mod with a little patience and it made a huge difference. Made my car look much more aggrssive.
I took off the bumper and a couple of screws around the head light housing. Disconnected the turning signal lights, Lo beams ,drl, and the amber light.
Pulled out the head lights and took out the 4 screws around the head lights. Then heatedthe sides with a heat gun. You can use an oven but mine was too small. For the oven method you preheat it to about 250 degrees (I may be wrong) for about 5-7 minutes. Remember to wear gloves or else your hand will burn
You can take a butter knife and open up the seals and pull apart the lens. Then unscrew the amber parts off and cover the holes with electrical tape.
After that do everything in reverse order. Re screw, re heat the glue and firmly press the lens back together. I added more sealant using OEM Honda sealant. Then bam you got yourself a modded headlight
