1 - 3 of 3 Posts
MADART
Shot Gun Shack Queensland Australia
The new (used) BBS wheels I picked up cheap fitted fine on the test fit, apart from one aspect.
The center holes were too small to fit the 64.1 Honda hub. They had to be taken out by about 4mm to fit over the hub lip, which is about 5mm high.
So it was take them to a machine shop or do it myself. The machine shop wanted $100 to do the job and that's $100 wasted from the new tyres I need for the wheels.
It was do a bit of research, choose a method, grit my teeth and do it.
Most of the DIY methods on YuTube involve using a router to chew out the center. I don't have a router, and don't like the idea that it's not a 'centered' method.
Then there's the dremel method, also not centered, and it takes hours.
I happened on some dude on a forum saying he'd used a hole saw. This sounded better as it could be centered and was close to center boring.
Went to the tool shop and bought a 65mm hole saw.
The first thing I had to do was find a way of centering the saw.
This was done by using the saw to cut out a circular blank from a piece of 1/2 inch soft wood. The wooden blank may then have to be sanded to fit into the front of the wheel hub, but I was lucky as there was a bevelled edge tapering into the wheel hub hole.
I then hammered (reasonably firmly) the wood into the bevel around the front of the wheel hub making sure it was evenly fixed. This gives a guide for the drill bit in the middle of the holesaw and the middle of the wheel so that the boring is even.
4.5mm in- nearly there.
Then it's just a matter of cutting the wheel hub from the back.
The lip on the Honda wheel hub is around 5mm high, so I only had to bore a little more than that depth into the hub to get clearance.
I used lots of cutting oil during the job, taking it slowly and stopping to clear out the built up swarf regularly. The drill was held at medium speed with only enough pressure to cut without binding and care was taken that it remained vertical and the cut even.
When each wheel is finished, just knock the wooden blank out with a hammer and insert it into the next wheel.
I did break the center drill bit once (on the third wheel) because there is some sideways pressure and tool steel wont take that. I inserted a piece of mild steel bar into the holesaw center (The drill bit is replaceable in the auger) instead because it can handle the pressure better than a drill bit.
Clean up the cut with a round file or dremel and it fits perfectly.
About 10 minutes a wheel and the holesaw cost $12, the cutting compound $9.
Hey Madart, saw this on the other forum. That's good work you did!
I would be worried that I'd get the hub bore off centre and end up with a wobbly tire.
Brave!
Brave!
Yeah, thanks. I was a bit nervous about it but it turned out fine. The thing is I figured that even if it went slightly off center, being at the hub and inboard of the lugs there's very little centrifugal force at play, unlike weight anomalies out on the rim.
1 - 3 of 3 Posts
