Drive Accord Honda Forums
Google
Thread Tools Rate Thread Display Modes
Old 10-06-2009, 08:07 AM
MotorCity Honda's Avatar
MotorCity Honda MotorCity Honda is offline
Swirl Free
Danase Water Spot Remover -- Quick Review w/ Pics
I used the Danase Water Spot product several months ago and have been meaning to share the results but have just not gotten around to doing so.
Bottom line, this stuff just plain works! This customer came to me thinking he needed a new paint job. The mineral deposits were so bad that he could barely even see out of his windshield. When I would gently rub my fingers on the deposits it sounded like I was rubbing my fingers on sand paper!
Any how, on with the pics... The entire car was riddled with these water spots as the customer had just moved to the area and didn't know how hard the water was and he left his truck parked next to a sprinkler that was watering new grass seed. New grass seed needs to be kept wet so the sprinklers were being used 3 times a day and the truck had sat right next to the sprinklers for a week while he was out of town for business.
The owner and his son tried all kinds of products before bringing the truck to me and nothing even made a dent in them. I thought I was going to have to use wool and compound to get them off, that is until I tried the Danase product.
On with the pics
This is indicative of what was ALL OVER the truck!
Before:
After (obviously I also corrected the paint):
Bottom line, this should be in every detailers supplies... You never know when a customer’s vehicle will need it!
2003 Accord EX I4- Satin Silver Metalic
Deep Gloss Auto Salon
Drive Accord
Old 10-06-2009, 08:14 AM
andrewd523 andrewd523 is offline
3rd Gear
Nice Job! What wax did you use, it looks incredible.
2008 Honda Accord EX I4 Sedan
Old 10-06-2009, 09:15 AM
RTexasF's Avatar
RTexasF RTexasF is offline
Old Bird...sometimes wise
Thanks, I had been wondering about that very product. What is the procedure for using it? Did it require multiple apps since the spots were so heavy?
The truck looks fantastic! Better than new even.
All I ask is a chance to prove that money can't make me happy....
Old 10-07-2009, 05:18 AM
08coupex's Avatar
08coupex 08coupex is offline
5th Gear
Amazing turn out. What did you use D.A., Rotory, Flex? What pad? Speed?
2008 Accord Coupe EX Silver
20% tint
Viper 5701 2-way Responder LE w/ remote start
Weathertech floor liners front & Back
OEM deck lid spoiler
Factory fogs added
Xenon depot 5k HIDs
Old 10-08-2009, 03:31 PM
needvoglights needvoglights is offline
3rd Gear
Thanks! Can we get the process, please?
2009 EX i4 Auto Sedan
My Installs/Opinons
Old 10-08-2009, 03:49 PM
searich07's Avatar
searich07 searich07 is offline
6th Gear
Good tip, thanks
http://danase.com/Danase-Detailing-P...emover-p4.html
8 oz $14.95
Danase Water Spot Remover was formulated for the detailers who demanded perfection without it taking all day to achieve. What was once a long drawn our process that took hours of elbow grease now is as simple as wipe on wipe off. Water Spot Remover will remove water spots and built up scum from paint, clearocat, and glass. Made from a mild acid base it breaks the bond between the mineral deposits and the surface. Regards
Richard
'09 Accord Coupe Ex L-Nav (190hp) I4
- Alabaster Silver Metallic/ Zaino finish / Black Leather Interior
-Weathertech trunk, front
-3M clear bra, pillars, roof, rear deck
OEM:
- side moulding
- fog lamps
- Auto dim mirror
HONDA Accords:
'99 Sedan EXL V6
76 K miles - 6th Gen (97-02) 3.0L V6 SOHC VTEC (200 hp)
'92 Coupe I4
127 K miles – 4th Gen (90-93) 1992 facelift I4 2.2L (125 hp)
'85 Sedan LX 4dr I4
98 K miles – 2nd Gen (82-85) 1985 refresh i4 1.8L (86 hp)
Old 10-08-2009, 07:02 PM
Swirl Free
Some areas took 3 applications due to the severity.. I used an old orange small pad and worked the product in and rinsed it off. The only deviation from the instructions was I used an orange pad.
This product DID NOT remove the swirls, just the water spots. I had to machine polish the swirls out.
For final protection I used Bilt Hamber Auto Balm... Amazing product.
Old 10-08-2009, 07:34 PM
Aviography's Avatar
(slightly off topic).....
Co-incidentally I was working on the humidfier on the furnace last night, the fancy mechnism on this humidifier is suppose to allow a certain amount of water from the pan to drain out every so many turns of the drum to prevent scale build up, had failed last winter so the water was draining rather quickly all the time, I decided I wasn't going to bother fixing it so I just clamp the drain tube shut.
As you can imagine the calcium build up inside the humidifier at the end of the winter was simply atrocious, I just left it since the damage was already done.
Looking at it last night, there was almost 1/4" thick crust of solid build up at the bottom of the pan, a thin layer on the float and other mechanism, I was able to crack and pop off the thick stuff, but there was still a good amount of stuff stuck to the bottom of the pan that just wouldn't come off.
I throw everything in the kitchen sink, filled it with regular tap water, and add a mug worth of white vineger into the sink and let it sit for the day.
All the scale easily came off the surface of the pan and the float with barely any scrubbing when I came home tonight.
I guess this water spot remover is probably based on the same acidic principle to react with the calcium in the hard water stain, but try cover the paint on the car with vineger for a day!
Great find, and GREAT work on the paint!
4,300K DDM slim-line HID conversion, TL shift knob, Hidden Hitch,
2007 Acura TL-S front/rear sway bars.
Acura TL 5-spoke rims and 235/45-17 Bridgestone Pole Position RE960 tires for summer
Honda steel rims and 225/55-16 Michelin Alpin PA2 tires for winter
DA Moderator Team
Old 10-08-2009, 07:55 PM
Drowzee Drowzee is offline
4th Gear
I just got a tin of AB. Awesome product, but a little tricky to apply.
Oh and nice turnaround with that car. Did you ever get a chance to use that AG CWC I sent you?
08 NBP Accord Coupe EX-L I4
4300k HIDs from XenonDepot
OEM foglights w/ 3000k HIDs from Retro-Solutions
35% tint all around
TSX Switchblade from Acura of Peoria
Weathertech Floorliner DigitalFit fronts only from Throwdown Performance
LED bulbs from Retro-Solutions
Debadged
Old 10-09-2009, 08:16 AM
08coupex's Avatar
5th Gear
Curious if this works on glass?
20% tint
Factory fogs added
Xenon depot 5k HIDs
Old 10-09-2009, 09:03 AM
SatinSilver's Avatar
6th Gear
Yes, according to the link above.
Matt
05 Toyota Matrix XR: Silver,at, 24k
99 Accord Coupe: 2.3 at, 166k, original owner.(sold)
94 Civic Coupe: manual (sold with 45k)
83 Cutlass Supreme Coupe: Traded in with 67k.
Old 10-09-2009, 09:38 AM
08coupex's Avatar
5th Gear
Thanks, someting else to add to the list.
20% tint
Factory fogs added
Xenon depot 5k HIDs
Thread Tools
  Friends of Drive Accord
Retro-Solutions
TV and NAV 2 Go
Diode Dynamics
Accord Mania
XenonDepot Lunarpages.com Web Hosting
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© Copyright 2002-2010 Wardsweb, LLC. All Rights Reserved.
